Go to Post CHALLENGE: A dozen Krispy Kreamers to the first team to make a three-pointer during a break at an NBA game. - Natchez [more]
Unread 05-09-2004, 00:24
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: pic: Iso view
Originally Posted by Arefin Bari
I should have made another thread about the gearboxes... but okay...
I am just wondering if your motor mounts are strong enough keep the drill motor from spinning out because of torque in the gearbox... i am saying that since i have experienced it... we had something like a mexican hat which held the drill motor in place and then bolted that into the gearbox plate...
The design looks great so far... whoever drew it... put some quality time in it... good luck...
Thanks,
We have used this type of mount on the chip motors in the past with no problems. The mount is slotted on one side only and the hole is bored to fit tight on the motor. We'll see if it works, if not redesign
-Rod-
Team 662
Colorado Springs, CO
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
