Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 07-09-2004, 16:53
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: Iso view
Originally Posted by Andy Baker
A few years ago, I was using 60% for what I called "working speed" (motor rpms at robot's top speed). The past few years, as our efficiencies have gotten better, this percentage of the free speed has gone up. Last year, we used 75%, I think.
I don't put too much faith in that number, though. It just gets us in the ballpark with regard to ratios, speed, and sizing. Our final number might have been 5% higher or lower, but it is about right.
John, you must have a very light robot or a very efficient drivetrain if you are running at 85% of your free speed.
Andy B.
Andy, I assume you are talking about a dual motor (2 CIM and 2 Drill) drivetrain. The percentage is obviously significantly lower when you have half the maximum power. This question might also explain the discrepancy between John's and your numbers.
Team 1257
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
