Go to Post Nothing you learn can truly prepare you for everything that comes your way. - sciguy125 [more]
Unread 09-09-2004, 23:55
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: pic: 6 speed?? Great in theory - lets see how it works!
Originally Posted by dez250
The only way i have seemed to get a pneumatic piston, like those in the kit that only have 2 ports to move to more then 2 positions well requires multiple pistons. Take 3 pistons, and put them in series (like one after the other). So when you have the all retracted its on the first length, piston a extended and piston b and c not extended is length 2, piston a and b extended with piston c not extended is length 3, having a not extended with b and c extended is length 4, having a and c extended with b not extended is length 5 and having all a b and c extended is length 6. Its actually works really well you just have to tweak it before it goes on the bot. So like resistors in series, you can get pistons in series in a way to act together like a single piston with multiple positions...
Hope that helped..
Except resistors are tiny and pistons are not
You are talking about fitting 5 or 6 pistons in a gearbox that's supposed to be a few inches thick...
I would go with a lead screw with a huge pitch, so that rotating it a few degrees would make the shifter move a considerable amount. Depending on the forces involved, a servo could be used to precisely turn the lead screw, sliding the shifter and making an accurate change of gears.
BTW, your design looks very good
PS: It's pretty late and I'm an Electrical Engineering student, so bear with me for any major mechanical inconsistency in this post
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
pic: Mock Competition at SWAMP WORKS CD47-Bot Extra Discussion 1 06-06-2004 19:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
pic: Wouldn't that be great? CD47-Bot Extra Discussion 2 28-04-2003 12:25
