Go to Post GP is a code which is lived by, not a yardstick to measure others by. - Daniel_LaFleur [more]
Unread 10-09-2004, 06:43
President, VEX Robotics, Inc.
Re: pic: 6 speed?? Great in theory - lets see how it works!
Sean,
Looks very good, but I would like to see more detail on the gears (diametral pitch, backlash, etc.) in order to comment on robustness. With respect to the shifting, I would scrap the pneumatics idea and go straight to a ball screw or a lead screw. You could get VERY accurate positioning from that set-up and you could use the seat motor or globe motor. The issue is speed of shift so the globe motor might be the best candidate. For position sensing you could use limit switches (not what I would use) or a rotational encoder (digikey has a lot of choices). Using a motor/balls screw set-up like this will give you stiffness, accuracy, and repeatability.
-Paul
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
pic: Mock Competition at SWAMP WORKS CD47-Bot Extra Discussion 1 06-06-2004 19:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
pic: Wouldn't that be great? CD47-Bot Extra Discussion 2 28-04-2003 12:25
