Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 10-09-2004, 07:36
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
Re: pic: 6 speed?? Great in theory - lets see how it works!
roffle... ever considered hooking up a motor to the shaft that the shifter is on, and making the shaft itself grooved (like a worm gear) and fix it so that the shifter can't rotate (i.e. just throw another shaft through it at a point) so when the motor turns, the shifter will run along the shaft. Probably not the best way, but it's an alternative to all the pneumatics.
Just thought I'd toss something else new and whacky out there since this thread is just asking for that stuff.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
pic: Mock Competition at SWAMP WORKS CD47-Bot Extra Discussion 1 06-06-2004 19:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
pic: Wouldn't that be great? CD47-Bot Extra Discussion 2 28-04-2003 12:25
