Go to Post Make the next 20 years great. - Doug G [more]
Unread 10-09-2004, 16:38
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Re: pic: 6 speed?? Great in theory - lets see how it works!
In theory, it is possible to have an infinite stage gear. Put threads on a cone and put a FIRST gear (the sideways ones in the kit) on top of it. Adjust its position with a weak motor, and you should be able to deliver the exact amount of torque that you want. I will put up drawings later when I scan them in (yep, i'm a paper and pencil designer), and I may even put it in a white paper. whether it will work.....
It's possible to have an infinite stage gear system but Im not sure if what you say will work. It's called a cvt or cct. I forget.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
pic: Mock Competition at SWAMP WORKS CD47-Bot Extra Discussion 1 06-06-2004 19:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
pic: Wouldn't that be great? CD47-Bot Extra Discussion 2 28-04-2003 12:25
