Go to Post Our robot-in-progress got set on the scale yesterday, It came to about 115 pounds. Then I walked up and took out the battery, and everyone relaxed some. - Alan Anderson [more]
  #37   Spotlight this post!
Unread 12-09-2004, 13:12
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Re: pic: 6 speed?? Great in theory - lets see how it works!
Originally Posted by Tristan Lall
By the way, for a 6- or even a 4-speed version to work well (it seems to me, anyway) that you'd need to be able to shift on the fly, even while pushing something, or crashing at high speed into something. (Because the chances will be higher that you'll be in the wrong gear for something, as you're doing it.) I think you've addressed that, but just in case it wasn't a priority--please make it one! Part of that involves using sufficiently robust gears, since a partially engaged gear does not evenly apply its load to the entire face width!
The design intent is shift-on-the-fly capability. How well it works will remain to be seen. We plan on auto shifting - requiring a driver to also manage which gear he/she is in is not something we want to do.
We would like our shifting mechanism to be fast AND accurate enough to engage the vast majoirty of the gear even in the heat of battle. Double-edged sword whether to go with wider or narrower gears. Wider gears mean more strength but also mean more travel to fully engage and more weight. Narrower gears are lighter and quicker to engage but may not have the necessary strength. Time to add some math to the design mix.
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
pic: Mock Competition at SWAMP WORKS CD47-Bot Extra Discussion 1 06-06-2004 19:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
pic: Wouldn't that be great? CD47-Bot Extra Discussion 2 28-04-2003 12:25
