Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 16-09-2004, 21:15
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Re: pic: 1305 Frame design with trannies
Originally Posted by sanddrag
What is the thickness on the outer plates and on the wall of the tube. I'm guessing it is 1/8" If so, the plate needs standoffs between it and the tube, and the tube needs some serious HOLES. Also, other than mounting your trannies? is there any reason that tube is so big, I mean, for the rest of the way down the frame?
Like I said before it designed to fill the bulldozer role on the field. Those are the 2x4x1/8 tubes like we got in the kit last year, and the outside plates are 3/16. there will be standoffs as part of the track system, but I didn't add them in yet. both the 2x4's and the outside plates will likely end up full of holes in the final robot (If it turns out that we can even use this design next year), then we will just Epoxy a piece of 1/16 lexan over the holes on the outside plates to keep stuff from getting caught in them (bad experience in atlanta with stuff catching in holes).
If we end up building this we will deside where mechanisms need to be mounted before drilling any lightening holes to make it easy to mount stuff.
By the way the bottom plate is only 1/16, just to help keep the frame square and mount stuff like the battery and electronics to.
pic: My vote for the best design from the team spirit "drawn" in the stands. CD47-Bot Extra Discussion 4 07-09-2004 00:19
pic: Team 303 Winner of the GM Industrial Design Award CD47-Bot Extra Discussion 9 20-04-2004 19:57
pic: team 1305 - The Mammoth Ayu Robot Showcase 2 04-03-2004 23:33
pic: 1083's final design unleashed!!!! The MIKEBOT 2000 CD47-Bot Robot Showcase 8 20-02-2004 23:41
pic: Team 710 Frame CD47-Bot Extra Discussion 4 16-02-2004 19:01
