Go to Post It's not about a team having lots of money to spend to travel the world to share FIRST but how the team draws the world into their FIRST experience. - Steve W [more]
Unread 18-10-2004, 12:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Is a shifting transmission really necessary?
Originally Posted by Al Skierkiewicz
...The difference between 8f/s and 12 f/s is only 2 seconds from end to end...
That means you can get to the center of the field a full second earlier. In the 2004 game, beating the opponent to the bonus ball tees and mobile goal in autonomous mode was critical to many teams' success. Two seconds is not terribly important in itself, but in competition against another robot every advantage helps.
A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage.
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
