Go to Post Programming isn't that hard once you get the hang of it. It has a steep learning curve like math. One day your trying to figure out 1 1, then the next day they throw x and y at you. Once you understand what x and y represent and learn to think in terms of functions, it's as easy as pi. - sciguy125 [more]
Unread 30-11-2004, 21:08
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
Thumbs up Re: pic: Version 1.1
Hey Arefin,
It looks very good, I can tell you have worked hard in it and it would be interisting to see every modification that you make to improve it.
Good Luck
Unread 30-11-2004, 21:20
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
Arefin nice job on the gear box. now how is inventor? just so proud of you. first you could not get inventor now you can, good job.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 30-11-2004, 21:25
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
okay. awesome arefin. great job working with inventor.
now for the Critiquing...
i question the sheer size of this gearbox and the long skinny standoffs holding the plates together. the CIM is a 300 watt motor Perfectly capable of bending, breaking and shearing aluminum with its torque. secondly i suggest some machining to remove material from those gears, i say this not from a weight standpoint but rather from an inertial standpoint. a robot traveling in one direction at full throttle having to slam it into reverse or turn would benefit from less inerta in its gear train simply because its easier, more efficient and takes less time and energy to reverse the direction of a 4oz gear then an 16oz gear. the mass of your gears along with the skimpiness of your standoffs is a deadly combination. also removing the hubs making speed holes and using key ways, or if you don't have a broach witch is most of us try using one of the various locktite products for binding rotational parts together. the stuff works great and it doesn't take much work to use it. i would also suggest that instead of using the clevis's for mounting the cylender i would suggest you drill a hole in your plate and use the threads of the cylender as a bolt and lock it on with some 5/8-18 nuts that would also then act like an extra standoff for you. On the happy side, i like how simple your shifting is. just slide the gear easy right? well, make shure you chamfer the edges of the gears that are meshing into each other to keep them from grinding when you shift. Well, thats my twoCents.
Unread 30-11-2004, 21:33
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
thanks everyone...
thanks tytus for your input... i will consider all of your suggestions. i did think about the sheering problem. but seems to be i solved it (Thanks to JVN). Also thanks to greg for giving me his inputs for this transmission... this is only version 1.1, this transmission will be modified a lot of times.
and tom... greg is way smarter than i am. i have to learn a lot to get there...
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Hey man, it looks great!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
