Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Unread 30-11-2004, 22:16
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Version 1.1
Max, Thanks for your input... yes those are all 20 dp gears... but i am thinking about switching them to 16 dp gears. the shifter works fine. and thanks cory for answering the last question.
Edit - Also there will be holes in each gear just not to reduce weight but for what tytus pointed out (look at his post above). Each gear will be anodized.
EDIT- didnt want to post again... so here i go replying to alex from 469. yes i am considering what tytus has said. Also (if you see in the description of the picture) i am planning on moving the motor between the two plates. if i leave it like that i will sure mount it on the chassis somehow to make it stronger. thanks for your inputs.
Unread 30-11-2004, 22:34
If your gears are steel, I don't believe they can be anodized. And if they were aluminum, why would you anodize gears? It would add extra "thickness" on every anodized suface (not much but enough) which could cause a problem with teeth meshing. The only anodized gears I've ever seen are made from stock that is already anodized, then the gears are cut leaving a fresh precision surface for the teeth.
Perhaps you meant hardened?
Unread 30-11-2004, 22:36
AKA: Ari
yup .. sorry for the confusion... i meant to say harden the aluminum gears...
Unread 30-11-2004, 22:41
Why aluminum and not steel? I'm always a fan of saving weight (aren't we all) but I like to keep a bit of "beef" in areas prone to failure, or where I have seen failure before.
I don't know enough to do the calculations, but if someone can mathematically convince me that aluminum 20P gears are suitable in a FIRST robot gearbox application (even say non-shifting), then I'll run right out and by some.
But, because I can't mathematically prove or disprove the success of aluminum gears, I always just opt for the safer side and go with steel, as do most teams I assume.
If someone has done an aluminum geartrain and it worked, I'd love to hear about it and see some pictures. If anyone thinks it will work, I'd love to see some calculations. I'm not by any means saying it does or will not work, I am saying I have no clue and would really like to find out.
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
