Re: pic: Version 1.1
You need to adjust the spacing on the shifting shaft. By the picture you posted, I can see that there needs to be more lateral play on the shaft. The current setup allows for both gears to be engaged at the same time. You need to have space so that one gear is fully disengaged before the other is engaged.
| Linux and new microcontollers. | djcapelis | Programming | 48 | 29-01-2005 00:26 |
| pic: pic 1 | CD47-Bot | Robot Showcase | 6 | 22-02-2004 00:29 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
| Q&A Watcher Available for Download | Nate Smith | General Forum | 11 | 19-12-2002 11:12 |
