Re: pic: Version 1.2
nope the gears doesnt conflict. I have spaced it to have enough room for shifting.
Arefin....great gear box! Keep making it better and better and someday people may say your name along with JVN, Brockaway and Baker. I can see it "I am AREFIN!" haha I give it a 2 thumbs up!
-Kyle |
that cylinder rod is going to bend if the gears Jam, try moving the cylinder so the piston so its in line with the shifter shaft, that means taking it out of the box. but at least it wont make you have to take your gearbox apart remove the old cylinder, find a new one and put it all back together before your next match when you bend it.
Arefin,
since i've been working with you on these designs, i have seen what seemed like a rookie design turn into what seems to be a high class design. A few things im still hoping you change, is that you adapt the cylinder so it sits inside the box more and takes up less space. HOWEVER...everything seems to be amazing and FIRST class ![]() keep up the good work, and "your welcome" ![]() |
could you move the cylnider so it is sitting on top of the shifting gear instead of taking up space over on the side?
#10
Looks good,
Only thing would be the forementioned cylinder placement and possibly a bigger gear on the CIM shaft to give the space requierd between the body of the CIM and the gear on the 1st shaft to move the motor to the other side of the plate. Keep it rockin Arefin . |
#11
exactly right... i am going to work on it right now... thanks. |
| Linux and new microcontollers. | djcapelis | Programming | 48 | 29-01-2005 00:26 |
| pic: Version 1.1 | Arefin Bari | Extra Discussion | 24 | 01-12-2004 21:58 |
| pic: Panoramic Pic from Nationals 2001 | CD47-Bot | Extra Discussion | 19 | 23-03-2004 23:38 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
