Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
Unread 02-12-2004, 20:41
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Re: pic: Version 1.2
that cylinder rod is going to bend if the gears Jam, try moving the cylinder so the piston so its in line with the shifter shaft, that means taking it out of the box. but at least it wont make you have to take your gearbox apart remove the old cylinder, find a new one and put it all back together before your next match when you bend it.
Unread 02-12-2004, 20:45
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Thanks Tyty, i was thinking about it. i do have a feeling that something is going to bend. i think i am going to move the cylinder outside. i do have to think about it a bit more before i change anything. stay tune for V 1.3
Unread 02-12-2004, 20:55
Greg Perkins's Avatar
7 years, allready!!???!?!?!
AKA: Mongo
Arefin,
since i've been working with you on these designs, i have seen what seemed like a rookie design turn into what seems to be a high class design. A few things im still hoping you change, is that you adapt the cylinder so it sits inside the box more and takes up less space. HOWEVER...everything seems to be amazing and FIRST class
keep up the good work, and "your welcome"
Unread 02-12-2004, 21:00
could you move the cylnider so it is sitting on top of the shifting gear instead of taking up space over on the side?
Unread 02-12-2004, 21:26
AKA: Ari
great idea tom, sure i can do that. but in order to do that i have to extend the plate. i dont see anything wrong with it. at this point, i am not worried about having the tranny go a little bigger, i want to perfect it.
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
pic: Version 1.1 Arefin Bari Extra Discussion 24 01-12-2004 21:58
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
