Go to Post Attitudes in one part of life tend to carry over to others. - Wetzel [more]
Unread 23-12-2004, 02:30
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: Shifting Mechanism 222
How much of that shaft did you manufacture yourself? I am especially interested in the internal shaft.
See you in DC!
Unread 23-12-2004, 09:41
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Thumbs up Shifter mech.
Kudos to your design team ,
My question for you, "What device do you use to engage the three detent positions on your shifting shaft?" I've seen small pnuematics on two speed trannies and even built a CD two speed using the drill planetary set using a servo. I have some doubts about a servo having enough torque for this applicatin
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 23-12-2004, 11:06
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I didn't machine the shafts because of the level of accuracy that they needed to be; I was busy making other components of the robot/transmision.
Everything on our robot is built in Tunkhannock High School by students with the help of mentors.
The only thing we had to "outsource" for these transmissions from the school was the shafts and gears to get heat-treated, since our school does not have this capability.
They were made in the school and then taken to some company for the heat treating.
Shifting Question:
Our transmission really does not take that much strength to change gears. The main thing they need to shift is accuracy. We used two small pneumatic cylinders to shift.
On cylinder moved the transmissions to either first gear or third gear; the other cylinder was used to wedge the shifting forks into second gear. This required the cylinder that shifts the gears from first to third to become pressureless.
Here is the best pic I can find at the moment:
http://www.tigertrons.com/2004/2004bot3.JPG
Also more pictures can be found here:
http://www.tigertrons.com/pictures.htm
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 23-12-2004, 11:53
Stu Bloom's Avatar
FRC #1018 (RoboDevils)
Very, very nice ... do you have any drawings and/or CAD files you wish to share??
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
My activity for 2012:
  • Midwest Head Ref - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
pic: Tigertrons 222 Memorial Day Parade CD47-Bot Extra Discussion 11 17-06-2004 14:51
pic: 222 2001-2004 robots CD47-Bot Extra Discussion 16 20-05-2004 21:09
pic: 222 3 speed closeup/cutaway CD47-Bot Robot Showcase 64 25-04-2004 15:25
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 11-03-2004 21:39
pic: Team 60 Mechanism CD47-Bot Robot Showcase 2 11-02-2004 21:47
