Go to Post The ever popular Safety Tip Of The Day: Do Not Lick Wheel While In Motion The other popular one was: Remember Stupid Hurts - Joe J. [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 30-12-2004, 18:22
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: creating new boot disk
For the purposes of this answer, I am going to assume that your 80GB (current boot and main) drive is an IDE disk, on the first channel, and connected as master. And I am going to assume that the new 160GB disk (the master-to-be) is an IDE disk on the first channel, connected as slave. I am also going to assume each disk is set up with one large partition, the whole size of the disk.
First, backup anything that is important. You can never have too many backups.
Second, download a Knoppix linux CD and burn that image. Knoppix is a LiveCD, a disc that contains a version of Linux which does not need to be installed. If you are familiar with linux, good. It will really help while doing this.
You will need to boot into Knoppix and mount your hard drives. To do that, boot from the CD, open a terminal window once KDE has loaded, and type:
su (switches to root user)
mkdir /1 (makes a directory called 1 in the root area)
mkdir /2 (makes a directory called 2 in the root area)
mount /dev/hda1 /1 (mounts your existing hard disk in /1)
mount /dev/hdb1 /2 (mounts your new hard disk in /2)
cd /2 (move to /2 directory)
tar -cvzf 1.tgz /1 (archive /1 into a .tar.gz file)
mv 1.tgz 1.tar.gz (rename 1.tgz to 1.tar.gz)
gunzip 1.tar.gz (ungzip 1.tar.gz)
tar -xvf 1.tar (unpack that tar file)
The reason I recommend you to use tar rather than a direct copy is simple. You can store that 1.tar.gz file on another computer or a reliable medium, and have a record of your computer which you can restore from in case of disaster. After you are done with the above steps, you are free to swap the positions of your IDE devices. You will need to boot using a Windows 2000/XP install CD into the recovery console and run "FIXMBR", but then the swap will be done.
This is not an exercise to be taken lightly. If you did not understand any step above, do not try it.
Edit: I forgot about Norton Ghost. It should be able to do the whole process automagically. I have never used it and cannot comment on its use(ful/less).
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 30-12-2004, 19:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I highly recommend the Ultimate Boot CD
It's a compendium of useful utilities on one bootable CD. I think in this case, you can use HD Clone, as it says it supports copying one drive to a larger drive.
EDIT: after copying, use one of the partition resizing tools to claim all the extra space on the HD.
Unread 30-12-2004, 20:25
REVving up for a new season
FRC #2848 (All-sparks)
very very easy
format the new HD into 2 partitions both NTFS (80 gb each)
go get a copy of norton ghost and you can do 1 of two things
you can ghost the hard drive straight to each other or you can create a ghost image of your drive then burn that image to the new drive very simple.
you might also want to get a copy of partition magic it is also a good tool if you need to modify your partition sizes
Greg Needel│www.robogreg.com
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Operator Interface Problems - Won't Boot Jamie_Richard Control System 1 14-02-2004 17:20
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
