Re: White Paper Discuss: Triple Play Scoring Spreadsheet
The "blue end zone" field doesn't work properly. It isn't sending any data to field I10. I10 isn't calculating the score for having all 3 robots behind the end zone in I2. Instead, the "red end zone" (H2) field controls both scores, adding 10 to both.
This is the corrected field for I10: Code:
=((C2+E2+G2+G6+E6+C6+C10+E10+G10)*3)+(SUM(C3,E3,G3,C7,E7,G7,C11,E11,G11))+(IF(I2=3,10,0))+(IF(AND(B4=CHAR(66),D4=CHAR(66),F4=CHAR(66)),10,0))+(IF(AND(B8=CHAR(66),D8=CHAR(66),F8=CHAR(66)),10,0))+(IF(AND(B12=CHAR(66),D12=CHAR(66),F12=CHAR(66)),10,0))+(IF(AND(B4=CHAR(66),B8=CHAR(66),B12=CHAR(66)),10,0))+(IF(AND(D4=CHAR(66),D8=CHAR(66),D12=CHAR(66)),10,0))+(IF(AND(F4=CHAR(66),F8=CHAR(66),F12=CHAR(66)),10,0))+(IF(AND(B4=CHAR(66),D8=CHAR(66),F12=CHAR(66)),10,0))+(IF(AND(F4=CHAR(66),D8=CHAR(66),B12=CHAR(66)),10,0))-(I6) Last edited by Adam Richards : 09-01-2005 at 15:38. |
ENJOY!!! |
Perhaps I'm being a bit picky...but I like the new feature about only having ownership if you have a tetra of your color. Could you also add that if, for example, blue has a stacked tetra and red only has contained tetras, that the goal cannot go to red? (and vice versa with red on top and blue below) Not really sure where in the code to put it but something like IF(B2=0,IF(C2>0,IF(B4="R","ERROR",0),0),0) with all the ANDs and ORs added in for each case. If not its okay - its still a really cool spreadsheet
| White Paper Discuss: Continuous Improvement Process for FIRST Teams | Chris Fultz | Team Organization | 2 | 05-01-2005 20:52 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
| White Paper Discuss: Championship 20004 results for all divisions | CD47-Bot | Extra Discussion | 1 | 23-04-2004 02:05 |
| White Paper Discuss: Team 234 Cyber Blue Chairman's Submittal 2004 | CD47-Bot | Extra Discussion | 1 | 19-04-2004 10:56 |
| White Paper Discuss: Pocket PC 2002 Scoring Program | CD47-Bot | Extra Discussion | 3 | 16-01-2003 09:45 |
