Re: Scripting Setup and the Camera + Serial Port Drivers
If you try to use every motor and actuator in the kit, you will be about 60 pounds overwieight. Set your priorities. What does this robot NEED to do? Now look at options. What will give you a winning design? To quote an Eagle: Get over it... |
No, no . . .
Kevin Watson has basically saved our program for the past two years, I am not trying to imply that he or FIRST has fallen down on the job in any way, rather, I am saying that there is a big challenge for the teams to overcome. My post was not to complain about what is, but rather to elicit help for the serial driver problem, which frankly, has me stumped. |
Likewise, so am I... It is one of the reasons I posted on another thread when people said that they had made the software too easy...
Resolving I/O and interrupts will also be a challenge for the team who wants to do everything... Let the mayhem begin! |
Another question: The rules allow us to have secondary processors. So could you have a second processor which does nothing but service interrupts, and then passes bytes along to the FRC controller in a TTL type format.
Good Point
Hey,
Can someone point me to a tutorial regarding interrupts, and their implementation? I would much appreciate it, thanks in advance. Dan |
I think that for the IFI controller, your best bet would be to go to www.kevin.org/frc, download the code, and read through the lengthy explanation at the beginning of the interrupts.c file. Also, just play around with the code a little, it will both give you a sens of interrupts, and show you how they work on the IFI controller.
Thank you for your prompt reply, Dan |
#10
I cannot think of anything specific, however, the C tutorial on the FIRST website is quite good, it discusses programming in C for machines (read robots) in some detail. In addition, there is a 900+ page user manual on the PIC18 microprocessor (the one in the IFI controller) I would not reccomed this as recreational reading, however, I have never gone to it with a specific question and come away emptyhanded.
#11
To further that reply, check out the manual on the IFI website (www.ifirobotics.com) and on the Microchip website (www.microchip.com).
I have a mirror of the IFI documents section. If you have trouble finding what you need I can look through my dump. |
#12
Again, thank you for your reply. I will do as you say and read the tutorial on the FIRST site, though I think i might be able to skip chunks of it, and I will reference the PIC Manual as needed.
Again, thanks, Dan |
#13
Check out the programming whitepapers on this site. There's one called Interrupts for Dummies. Excellent
#14
http://www.ifirobotics.com/docs/time...004-jan-14.pdf gc |
#15
-Kevin Last edited by Kevin Watson : 12-01-2005 at 16:33. Reason: Icky spelling error. |
| UTC Hartford and the Pits in 2001. The same setup for this year??? | Elgin Clock | Regional Competitions | 3 | 01-11-2002 19:11 |
