Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 16-01-2005, 00:00
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Re: pic: Cooney Quest 269 Final Robot #2
Originally Posted by sanddrag
See, that is the interesting part. We never received four CIM motors before so I'm guessing this is a little more than just a mock-up. I have a feeling your actual robot will look more like this than you'd want us to know.
Anyway, you appear to have a worm gear drive for the CIM motor on each wheel. Could you please explain why you think being non-backdriveable is important and also why you are settling for a lower efficiency? Thanks.
the worm drives are there basically because they give us the reduction we need in i very small package, each of those gearboxes as you can see fit nicely off in the corner of the robot and we can build anything we want around them. The non-backdriveable part is just a byproduct of using the worm gears and not our reason for using them. As for settling for a lower efficiency, these are basically the same gear boxes we used last year for our two wheel drive system and were completely satisfied with their efficiency, performance, and robustness.
the interesting part of this drive is what lies between the two front wheels and the two rear wheels, although not readily visible in the photo
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
