| Thread Tools |
Rating:
Display Modes |
#31
Re: White Paper Discuss: Nothing But Dewalts
Give us a call and if you need clamshells, help or advice we are willing. 254-501-0987 Joe P Team 647 Shoemaker Cyberwolves |
#32
i think that they are interfaced to drills, but you dont need that this year (no drill motors.
#33
Read the paper, see if you don't agree. Joe Jl |
#34
Full Disclosure
I have gotten this question via e-mail:
I thought I would share this exchange with folks in the interest of full disclosure. Joe J. |
#35
Re: Full Disclosure
After thinking about what you had suggested about using a shaft collar and washer instead of the top hat, I thought I might as well use the shaft collar to help transfer power, too. You can bolt the carrier gear to the shaft collar and not worry about the press fit.
#36
can someone please toss me some general dimensions for the stock dewalt transmission. i don't have one in hand yet...any general length and width dims would be appreciated. thanks.
#37
If you are talking about the version mated to the CIMs without a servo, I can help you. I used some pixel counting on the pictures in the document (so this is all pretty approximate) and got the following.
Distance to 1/2" shaft from large face of CIM 3.7" max diameter from CIM to 1/2" shaft 2.7" 1/2" shaft with sprocket, bolt, etc 1"x1" cylinder Last edited by Max Lobovsky : 16-01-2005 at 13:08. |
#38
thanks for that. can someone who has one of these trannys, even a stock one take an overall length measurement from the end of the shaft. thanks you.
my assembly will be using the fisher price so i just need a general length measurement. |
#39
Joe P |
#40
thanks
#41
The paper suggests that "software synchronization" may be possible for shifting the transmissions. I believe I understand what synchronization is in a shfting transmission; it's waiting until whatever you are shifting is lined up with whatever you are shifting into so that no grinding of gears or shifters occur. Now how could this apply to the DeWalt transmission? How could you tell when the gears are in the right position to shift?
#42
First off I want to say that this is a great white paper. It makes it a lot easier to start more teams in an area with a small mentor base with ideas like this and AndyMark. I can't wait to try my first DeWalt transmission!!
I do have a couple questions while I wait for my order to come in. What modifications are required to the fisher price pinion? Has anyone mounted a gear to 1/2" shaft? My first impression is that a gear would produce a smaller side load but without a transmission in hand I may be missing some issues with mounting accuracy. Thanks again! |
#43
same for me.......did anyone toss a spur gear on the drill output last year......if so with what implications?
#44
Modify motor adaptor Make a plate that holds motor to adaptor Get Planet2 from extra transmission, enlarge hole to 1/8, press off 13T that is on FP, press on 1/8 bore Planet2 onto FP Mix well... ...Done! Quote:
Joe J. |
#45
Re: Full Disclosure
| White Paper Discuss: Users Guide to Autodesk Inventor | CD47-Bot | Extra Discussion | 2 | 18-12-2006 17:45 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
| White Paper Discuss: Karthik's Championship Event Data | CD47-Bot | Extra Discussion | 20 | 13-04-2004 08:17 |
