Go to Post I predict someone has to eat a hat! :D - FiMFanatic [more]
Unread 18-01-2005, 22:57
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
pic: 710 Teaser
Hows my searching? Call 1-800-Green-Dots
Unread 18-01-2005, 22:58
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: pic: 710 Teaser
Wow, shiney metal!
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: pic: 710 Teaser
hhmm I am calling it to be a possible design for LAST YEAR that they are throwing out as a joke. I think I also see ta part of the bosch drill motor mounts in the backround, just the right... we didn't get those this year , with no drills and all
edit:
oh oh oh, I also think that the plywood it is on is the wood from the stationary goals last year... the base, although that could be kept around till this year, just another thought...
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 18-01-2005, 23:02
WildEmerica's Avatar
WildEmerica WildEmerica is offline
Missta Roboto
AKA: Hip moma joma
#0957
WildEmerica has a little shameless behaviour in the past
Send a message via AIM to WildEmerica
Re: pic: 710 Teaser
As you can tell by the holes in the gears, it obviously is going to sheer the instant you try to pck it up,let alone put it in a gear set up.
I think the shinyness of the metal can directly relate to the speed of the output shaft since the tortional rate will warp the reflective power of the metal. why must you make me think once again harder than ever!
error.Future signature unable to load to past software.
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: 710 Teaser
I'd say that they are tetra manipulators yet to be tested.
See you in DC!
Unread 18-01-2005, 23:04
Re: pic: 710 Teaser
those are not drill mounts, those are bearing mounts to support it on the frame (notice the bearing is the same size as the half a hole....
Unread 18-01-2005, 23:05
Ryan Foley Ryan Foley is online now
FRC #5687 (The Outliers)
Re: pic: 710 Teaser
edit:
Good eye Henry
http://www.firstrobotics.net/04Galle...0710-1_jpg.htm
look closely at the drive
Nice try 710. I like what I see in your other picture though!
Ryan
FRC/FLL volunteer since 2005
Unread 18-01-2005, 23:07
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Re: pic: 710 Teaser
Eh.. I still think it is from last year
I don't think the gear will shear... my team has used many like it.
Also, I think it is a pretty beefy design to put on the end of an arm for a tetra manipulator.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 18-01-2005, 23:09
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: 710 Teaser
I am sorry, but all they did was take weights out of the sprocket... thats not a gear. there is nothing wrong with it and it wont break unless you up a LOT of torque on that one sprocket itself. On top of the sprocket there is a shaft coller which I am assuming they will bolt it on the sprocket and run the shaft through the collar.
-Arefin.
Unread 18-01-2005, 23:16
Re: pic: 710 Teaser
Your making me crack up, a martin heat treated/oil dipped sprocket rated it 32,000 pounds tensile strength is going to sheer and break? youve got to be kidding
Unread 18-01-2005, 23:20
Missta Roboto
AKA: Hip moma joma
#0957
Re: pic: 710 Teaser
Your making me crack up, a martin heat treated/oil dipped sprocket rated it 32,000 pounds tensile strength is going to sheer and break? youve got to be kidding, this must be your first year
Well, not quite. I come from the future and have the advanced knowledge of knowing what is going to happen. Please do not deny my knowledge
Unread 18-01-2005, 23:22
Re: pic: 710 Teaser
I believe you oh great one!
Unread 18-01-2005, 23:25
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Re: pic: 710 Teaser
Dude what??
Come on...really now, be reasonable.... if it meant to be a joke its not funny.
(Also.. because you are from the future shouldn't you have made the call that this desgin was from the past??)
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 18-01-2005, 23:38
RogerR's Avatar
RogerR RogerR is offline
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Re: pic: 710 Teaser
well, this drive module , which was used last year, seemed to hold up pretty well. but then again, the similarities might just be superficial.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 19-01-2005, 14:16
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: pic: 710 Teaser
just re-uploading to screw with my mind
I'm already so confused with all of the different rules this year
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
pic: SnoBot Teaser 1! CD47-Bot Robot Showcase 6 22-02-2004 20:59
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
pic: Robot Parts Fighters! (Or 810 Teaser #1...) CD47-Bot Robot Showcase 11 12-02-2004 16:44
pic: 225 Teaser CD47-Bot Extra Discussion 2 02-02-2004 13:59
