pic: 710 Teaser
Re: pic: 710 Teaser
Wow, shiney metal!
Re: pic: 710 Teaser
hhmm I am calling it to be a possible design for LAST YEAR that they are throwing out as a joke. I think I also see ta part of the bosch drill motor mounts in the backround, just the right... we didn't get those this year
, with no drills and alledit: oh oh oh, I also think that the plywood it is on is the wood from the stationary goals last year... the base, although that could be kept around till this year, just another thought... Last edited by henryBsick : 18-01-2005 at 23:03. |
Re: pic: 710 Teaser
As you can tell by the holes in the gears, it obviously is going to sheer the instant you try to pck it up,let alone put it in a gear set up.
I think the shinyness of the metal can directly relate to the speed of the output shaft since the tortional rate will warp the reflective power of the metal. why must you make me think once again harder than ever! |
Re: pic: 710 Teaser
I'd say that they are tetra manipulators yet to be tested.
Re: pic: 710 Teaser
those are not drill mounts, those are bearing mounts to support it on the frame
(notice the bearing is the same size as the half a hole.... |
Re: pic: 710 Teaser
http://www.firstrobotics.net/04Galle...0710-1_jpg.htm look closely at the drive Nice try 710. I like what I see in your other picture though! |
Re: pic: 710 Teaser
![]() I don't think the gear will shear... my team has used many like it. Also, I think it is a pretty beefy design to put on the end of an arm for a tetra manipulator. |
Re: pic: 710 Teaser
I am sorry, but all they did was take weights out of the sprocket... thats not a gear. there is nothing wrong with it and it wont break unless you up a LOT of torque on that one sprocket itself. On top of the sprocket there is a shaft coller which I am assuming they will bolt it on the sprocket and run the shaft through the collar. -Arefin. Last edited by Arefin Bari : 18-01-2005 at 23:18. |
#10
Re: pic: 710 Teaser
#11
Re: pic: 710 Teaser
Re: pic: 710 Teaser
I believe you oh great one!
#13
Re: pic: 710 Teaser
Come on...really now, be reasonable.... if it meant to be a joke its not funny. (Also.. because you are from the future shouldn't you have made the call that this desgin was from the past??) |
#14
Re: pic: 710 Teaser
Re: pic: 710 Teaser
just re-uploading to screw with my mind
I'm already so confused with all of the different rules this year |
| pic: SnoBot Teaser 1! | CD47-Bot | Robot Showcase | 6 | 22-02-2004 20:59 |
| pic: Team 1053's very first ever teaser pic | CD47-Bot | Robot Showcase | 3 | 16-02-2004 22:56 |
| pic: Team 782 teaser pic | CD47-Bot | Extra Discussion | 2 | 15-02-2004 23:53 |
| pic: Robot Parts Fighters! (Or 810 Teaser #1...) | CD47-Bot | Robot Showcase | 11 | 12-02-2004 16:44 |
| pic: 225 Teaser | CD47-Bot | Extra Discussion | 2 | 02-02-2004 13:59 |
