Go to Post A video is worth 30,000 words a second. - Thromgord [more]
Unread 20-01-2005, 18:58
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: pic: Team 121 Arm Proto
The arm works like a human arm: with a shoulder and elbow joint and hand (the part that picks up the tetra). You can use your own arm to test it out. With your palm up and arm straight, "drive" into a tetra, fold your arm up at the elbow until your hand touches your shoulder. Then rotate your shoulder up so your hand is above your shoulder and "drive" to a goal. When you reach a goal, rotate your elbow down so your arm is straight, "drive" forward so the tetra is over the goal, and rotate the shoulder joint down so the tetra is neatly placed on top of the goal. Back out and fold the arm back up for easy driving. Hopefully from the picture you can see the parts and motion I was describing. Hope that helps.
-Tom
FRC78: 2010-Present
FRC121: 2002-2009
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
pic: Team 980's arm hitting the stack at 2 seconds on clock CD47-Bot Robot Showcase 29 01-04-2003 21:48
