Re: pic: 222 TIGERTRONS TEASER
Of course we are supposed to think 5 speed based on your previous design, but I think there maybe a problem with that. 5 speed with pneumatics would require at least three cylinders per shifter which sounds like a bad idea. It's possible they are using a servo instead.
Hmmm...5 speeds or maybe 3 speeds with neutral positions??
It's also possible that the gearbox isn't shifted with pneumatics. It could be done with a threaded lead screw and a motor. Integrate a revolution sensor and it would work well.
I expect the same 3 general speeds as last year, with an added high torque super low speed, and a "crazy kill anything in its path" high speed.
I think we will see 3 speeds from them again this year. I think 5 is a bit ambitious and very unnecessary. But if you do have a strong 5-speed in competition, good job and kudos to you.
I would think that three speeds should be more than sufficient this year. High speed for sprinting, medium for meneuvering, and low speed for pushing other bots around. Then again our team is about 300 years away from every making any kind of gearbox, or even modifying the stuff we have to even get two speeds.
| pic: 222 Teaser #1 | henryBsick | Extra Discussion | 24 | 07-10-2005 22:54 |
| pic: Tigertrons 222 Memorial Day Parade | CD47-Bot | Extra Discussion | 11 | 17-06-2004 14:51 |
| pic: Team 1053's very first ever teaser pic | CD47-Bot | Robot Showcase | 3 | 16-02-2004 22:56 |
| pic: Team 782 teaser pic | CD47-Bot | Extra Discussion | 2 | 15-02-2004 23:53 |
| To T-REX Team 145 & TIGERTRONS Team 222 | purpledaisy | Chit-Chat | 0 | 13-04-2003 22:06 |
