Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
Unread 24-01-2005, 17:30
Re: pic: S.P.A.M "Littles-C" 12 speed transmission
well I can't say much either but I will say just as Dillard has: I've seen it, touched and and looked at it. S.P.A.M. is just wonderful what can I say. 12 speeds yeah we have nothing better to do with our time along with many other projects we do in the fall.
So yeah 12 speeds seems a bit much but hey it's us Speed Power and Maneuverability that's what S.P.A.M. is all about.
Unread 24-01-2005, 21:29
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
I'm a bit confused by the number twelve. With the most common shifting designs, you'd expect a 2^n number of gear ratios. But... 2 x 2 x 2 = twelve? They'd have to be doing something pretty ingenious.
Unread 24-01-2005, 21:47
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Maybe those are the most common shifting designs in the FIRST world, but when you look at the much larger world of engineering, there are numerous 5 and 6 speed car transmissions and I believe 18-wheelers have 12 speeds.
Team 1257
Unread 24-01-2005, 23:36
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
I am still sticking with this... The 12 speed is not meant to be used in competition. And somehow IF it were it is NOT a shift on the fly...or shift at all for that matter. It would be a pre-match selectable gear. The three speed shift on the fly IS their gearbox for the drive tain. PERIOD
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 25-01-2005, 13:30
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
-Henry
Henry, it truly is a 12 speed shift-on-the-fly gearbox...we aren't kidding about that. The designer (Cory Littles) had the inner works of a grandfather's clock in mind when he designed it. It has been tested on a chassis.
Gary DID say this thread might be ripe for the rumor mill (But seriously now, would S.P.A.M spread rumors? )
...Arefin, have you been spying?!?!
Don't PANIC!
S. P. A. M.
Unread 25-01-2005, 13:36
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Did it work well? What motors were you using and how fast could you go in the lowest and highest gears? Can't you share a little more information?
See you in DC!
Unread 27-01-2005, 12:44
FRC #0180 (SPAM)
Ok, I think this teaser has run its course.
The gearbox was built by Cory and his uncle for a "Barbie car" design they have been experimenting with. It can carry a pre-k child ~50lb. The front wheels steer and they've tried several combinations of all-wheel drive, by using 1 and 2 of these gear boxes. Cory tells me he powered it with a "big" RC car motor. The car is currently torn down and is one of his "once-in-a-while" projects. Why 12 speeds?...ah heck...why not?
Eric
Don't PANIC!
S. P. A. M.
Unread 27-01-2005, 20:07
Eric
You're joking right? A Barbie car? That's even more rediculous than having it for a FIRST robot. Anyway, does it work well?
White Paper Discuss: Team 33 Four Speed Transmission CD47-Bot Extra Discussion 10 19-04-2013 14:22
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
pic: S.P.A.M. Girls at the S.P.A.M. Team Party CD47-Bot Extra Discussion 6 03-05-2004 21:36
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
