Go to Post GP isn't just a good idea, it's mathematically optimal. - Jared Russell [more]
Unread 24-01-2005, 18:11
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: pic: 222 TIGERTRONS TEASER
Originally Posted by Max Lobovsky
Of course we are supposed to think 5 speed based on your previous design, but I think there maybe a problem with that. 5 speed with pneumatics would require at least three cylinders per shifter which sounds like a bad idea. It's possible they are using a servo instead.
After tinkering around with our 3 speeds from last year, we realized that it took almost no effort at all to move the shifting rod in and out to engage the gears by way of the balls.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 24-01-2005, 18:24
I expect the same 3 general speeds as last year, with an added high torque super low speed, and a "crazy kill anything in its path" high speed.
Unread 24-01-2005, 19:00
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
I think we will see 3 speeds from them again this year. I think 5 is a bit ambitious and very unnecessary. But if you do have a strong 5-speed in competition, good job and kudos to you.
See you in DC!
Unread 24-01-2005, 19:07
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Servo it is.
Team 1257
Unread 25-01-2005, 00:04
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I would think that three speeds should be more than sufficient this year. High speed for sprinting, medium for meneuvering, and low speed for pushing other bots around. Then again our team is about 300 years away from every making any kind of gearbox, or even modifying the stuff we have to even get two speeds.
pic: 222 Teaser #1 henryBsick Extra Discussion 24 07-10-2005 22:54
pic: Tigertrons 222 Memorial Day Parade CD47-Bot Extra Discussion 11 17-06-2004 14:51
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
To T-REX Team 145 & TIGERTRONS Team 222 purpledaisy Chit-Chat 0 13-04-2003 22:06
