Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Unread 25-01-2005, 00:55
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: PID code questions
Originally Posted by Dave Flowerday
The effect seen at kickoff was the loop overshooting. This can come from either too large of an integral term or too large of a proportional term or some combination of the two. The problem with PID loops is that it can be tricky to get the behavior "just right" such that the loop doesn't oscillate, doesn't overshoot, and has a fast rise time all while dealing with varying external forces. Most likely the problem stemmed from the fact that when Dave kicked the robot, the angular velocity that it encountered was much higher than what the robot was capable of on its own, so the PID loop was not as well tuned for it as when it was driving under its own power.
The proportional gain was set too high. The demo code was finished the evening before the kick-off and we didn't have/spend enough time tuning the 'bot. When we got it tuned to the point where we were (reasonably) confident it wouldn't slam into Dave's ankle, we quit for the evening <grin>.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
heres the code. y this not working omega Programming 16 31-03-2004 15:18
