Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 25-01-2005, 15:47
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Re: Extension lift mechanics
Originally Posted by Vash
Okay I guess I overdid it. From past experience members of our team insist on never trusting gravity.
Gravity is generally pretty reliable, but in this application you need to ensure that it is able to do it's thing. The key thing is to make sure that the sliding sections cannot tilt sideways enough to lock up. Gravity can only pull so hard, if it takes too much force to clear the jam then you will be stuck in the up position. If you want the belt and suspenders approach then you ensure that you pull down as well.
Our lifts have always been powered both ways. Keeping the lift from jamming up was one reason. But another is that gravity is not always pointing the same direction relative to the robot.
If, for example, your robot should fall over sidways with its lift extended then gravity is now pulling 90 degrees from the direction you originally intended. Your robot is now blocking a large part of the field, a situation which may not be desireable. If you power the lift down, then you can probably retract it and clear the field. It would also be easier for another robot to help you back up on your wheels. But if you are relying on gravity to lower the lift, then it is already as low as it will go.
Christopher H Husmann, PE
"Who is John Galt?"
**IMPORTANT FIRST EMAIL**/Robot Ship Extension News with Season Information and Upda miketwalker FIRST E-Mail Blast Archive 0 13-02-2004 18:02
Servos - How much can they lift? John JediMaster Electrical 23 31-01-2004 19:03
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
Window lift motors... David Kelly Motors 2 21-01-2002 00:03
