Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 27-01-2005, 19:59
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Re: pic: #1156 Under Control [Brazil] - Electrical components board
Originally Posted by Sscamatt
Looks great!
Not to criticize, but maybe you should take a look at this:
"For optimum power
distribution, the auto-resetting breakers should be installed from the lowest number to the highest
number. Thus a corresponding breaker should be installed in 1 first, then 2 …etc."
from: http://www.ifirobotics.com/docs/brea...005-revnc0.pdf
Shouldn't be too hard to fix and you have plenty of time.
Working on it.
Thanks a lot!
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 29-01-2005, 13:20
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Great job! It looks really organized! I only wish we could do something like that.
Just wondering: where did you order your wire conduit from?
Unread 30-01-2005, 17:45
Daniel_H's Avatar
We bought ours in a local store, and since we are from Brazil it won't be helpful =/
but you can ask team 27 where they ordered THEIRS
[<o>] gogogo [<o>]
Unread 30-01-2005, 19:40
alright... thanks!
Unread 30-01-2005, 19:56
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Very Nice Job. I am impressed. Keep up the good work.
-Rod-
Team 662
Colorado Springs, CO
2004 control board emulator CmptrGk Programming 4 04-09-2004 16:13
pic: Team 294 Control Board: View 2 CD47-Bot Extra Discussion 17 11-08-2004 17:21
frying control board Denman Technical Discussion 7 07-07-2004 19:11
Designs for control board? batbotcrewfrosh General Forum 6 05-02-2004 00:00
