Re: pic: Drilled out gears
John that is awesome. Great lightening pattern. |
My guess, we haven't seen the end of insane hole drilling in gears. Our team has a little something on those same lines....
I'll agree with Dave. We had drive sprockets last year and took a little too much off. They broke in post season with more events to go, so we had to replace them.So I'd say that if you must lighten a gear, do it a little at a time, preferably only if you are over weight or planning to be (in which case, the robot will start looking like swiss cheese).
Hey we drilled holes in our wheels to reduce weight.
It wasnt noticable, but it worked, and they were still reliable. |
FYI, Jon V-Neun consulted with me before his team modified those gears. I did a quick Finite Element Analysis and told him he could take more material off if he wanted too. The two big areas of concern are the area near the hex shaft and the area near the gear teeth.
John, That is a really cool pattern, by the way. A comment about Daves Picture: The main problem in the picture is that there are only two spokes holding the sprocket to the hub. That is an unstable solution. They could have gone with 1/3 the spoke width and added a third spoke and been fine. Notice the failure mode is in the bolt twist direction. A third spoke would have made it much more rigid/stable. -Paul Last edited by Paul Copioli : 28-01-2005 at 07:10. |
| request for info on gearbox gears | jskene | Technical Discussion | 0 | 08-01-2005 18:07 |
| pic: 2 speed, shift on fly | CD47-Bot | Extra Discussion | 4 | 11-10-2004 11:46 |
| pic: Iso view | CD47-Bot | Robot Showcase | 19 | 07-09-2004 17:38 |
| White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox | CD47-Bot | Extra Discussion | 9 | 30-08-2004 21:57 |
| Looking for KOP Helical Gears | ChuckDickerson | Kit & Additional Hardware | 1 | 21-07-2004 15:39 |
