Go to Post An inability to communicate your ideas effectively is a handicap you would be well served to strive to overcome. - Ether [more]
Unread 27-01-2005, 23:27
EricH EricH is offline
Re: pic: Drilled out gears
I'll agree with Dave. We had drive sprockets last year and took a little too much off. They broke in post season with more events to go, so we had to replace them.So I'd say that if you must lighten a gear, do it a little at a time, preferably only if you are over weight or planning to be (in which case, the robot will start looking like swiss cheese).
Unread 28-01-2005, 00:21
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Hey we drilled holes in our wheels to reduce weight. It wasnt noticable, but it worked, and they were still reliable.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 28-01-2005, 07:07
President, VEX Robotics, Inc.
FYI, Jon V-Neun consulted with me before his team modified those gears. I did a quick Finite Element Analysis and told him he could take more material off if he wanted too. The two big areas of concern are the area near the hex shaft and the area near the gear teeth.
John,
That is a really cool pattern, by the way.
A comment about Daves Picture:
The main problem in the picture is that there are only two spokes holding the sprocket to the hub. That is an unstable solution. They could have gone with 1/3 the spoke width and added a third spoke and been fine. Notice the failure mode is in the bolt twist direction. A third spoke would have made it much more rigid/stable.
-Paul
request for info on gearbox gears jskene Technical Discussion 0 08-01-2005 18:07
pic: 2 speed, shift on fly CD47-Bot Extra Discussion 4 11-10-2004 11:46
pic: Iso view CD47-Bot Robot Showcase 19 07-09-2004 17:38
White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox CD47-Bot Extra Discussion 9 30-08-2004 21:57
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
