Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Go Back   Chief Delphi > Technical > Control System
  #36   Spotlight this post!
Unread 28-01-2005, 11:57
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Playstation Controler
Originally Posted by AIBob
you cannot really use a ps controller, not because of the rules, but because of the way it is set up..
The controllers for FIRST are analog. PS controllers are digital.... it doesnt match, you will find some problems if you try it.
You cannot immediately write off using the PS controller for the robot, simply because it is digital and the controller has analog inputs. There are digital input on the controller as well, which gives that option if you can figure out how to make it work with those digital inputs. Also there is the option of producing a Digital to Analog converter. The same way that the robot converts the analog signal to digital so that it can process it, you can do the reverse and give it an analog signal from digital.
I'm sure you can find a digital to analog converter online.
Saying that something cannot be done, is always good inspiration for someone to find a way to do it.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
Joystick controllers archiver 2001 6 24-06-2002 00:57
joystick problem archiver 2000 12 23-06-2002 23:08
