Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Go Back   Chief Delphi > Technical > Control System
Unread 28-01-2005, 20:02
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Re: Left Handed Joystick
Originally Posted by Max Lobovsky
How are you planning to turn the mesh into a part? Some sort of rapid prototyping machine?
Exactly.
Through work I have access to an SLS (Selective Laser Sintering) machine. I can get 1 or 2 of something done for free by putting it in the extra space around the money jobs. If I have to build a lot of something, but not enough to make injection molding profitable, then I can rent time at a commercial service. For large numbers of small parts SLS can be affordable on a per part basis, if the parts are packed tightly.
While the calipers and 3d Studio approach might produce a usable product, it would take a lot of work to get it right. A laser scan like phrontist mentioned takes minutes and all of the holes at strange angles will be properly positioned. Why do it the hard way if you don't have too?
Christopher H Husmann, PE
"Who is John Galt?"
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
