#16
Re: pic: 121 Teaser
Logic says that since only about 10% of the chain is resting on the sprockets, then this is not the actual pivot point for the chain. I believe it is just a chain tensioner we are seeing to reduce flex in the actual chain run. It looks like the actual load bearing drive sprocket would be about a foot (or more) in diameter and located inside the limits of the chain guard guard that is showing in the top right?
As for it's application? I don't know. Lifting relatively small (as far as Navy boats go) boats out of the water? |
#17
Re: pic: 121 Teaser
Wierd thing is, if it isn't a torque transferring sprocket (just an idler or tensioner), why is it keyed?
#18
Re: pic: 121 Teaser
Re: pic: 121 Teaser
| pic: Team #1382 Teaser - Gear Box | tribotec_ca88 | Extra Discussion | 6 | 22-01-2005 20:02 |
| pic: Team 48 Teaser (?) - xtremachen 7.314159 | Travis Hoffman | Extra Discussion | 8 | 22-01-2005 11:37 |
| pic: Team 1053's very first ever teaser pic | CD47-Bot | Robot Showcase | 3 | 16-02-2004 22:56 |
| pic: Team 782 teaser pic | CD47-Bot | Extra Discussion | 2 | 15-02-2004 23:53 |
| pic: Team 100 Teaser | CD47-Bot | Robot Showcase | 3 | 11-02-2004 16:19 |
