Go to Post yeah, right - like anyone's going to pass up building a robot. - IbleedPink233 [more]
Unread 30-01-2005, 01:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: 121 Teaser
Logic says that since only about 10% of the chain is resting on the sprockets, then this is not the actual pivot point for the chain. I believe it is just a chain tensioner we are seeing to reduce flex in the actual chain run. It looks like the actual load bearing drive sprocket would be about a foot (or more) in diameter and located inside the limits of the chain guard guard that is showing in the top right?
As for it's application? I don't know.
Lifting relatively small (as far as Navy boats go) boats out of the water?
Unread 30-01-2005, 01:22
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: 121 Teaser
Wierd thing is, if it isn't a torque transferring sprocket (just an idler or tensioner), why is it keyed?
Team 1257
Unread 30-01-2005, 11:07
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: 121 Teaser
To run the shaft on the bearings so they don't put wear on the shaft itself.
See you in DC!
Unread 30-01-2005, 12:33
Fold em oval!
Re: pic: 121 Teaser
Setscrew wouldn't do the trick?
Team 1257
pic: Team #1382 Teaser - Gear Box tribotec_ca88 Extra Discussion 6 22-01-2005 20:02
pic: Team 48 Teaser (?) - xtremachen 7.314159 Travis Hoffman Extra Discussion 8 22-01-2005 11:37
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
pic: Team 100 Teaser CD47-Bot Robot Showcase 3 11-02-2004 16:19
