Go to Post Its a good bug too. :) - spadercool [more]
Unread 31-01-2005, 08:52
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: pic: Omni Idea
The way it's shown, I think it would come apart after the first side load. You can't take away the rim band and leave each spoke alone to withstand the torsional twist and bending it's going to get. But I was thinking maybe you could take a 1/16 metal/alum flat bar strip and wrap it around and loop it through those pvc's, then rivet them to the flats left on the rim band, it might hold up. But the pvc is too slippery alone. So I'd go get some rubber hose - whose ID was that of the PCV od. Then glue that on the PVC. You might have an OK omni. Or you could split the PVC, wrap it around the wheel rim without cutting the rim. Then glue on the hose again with the splits offset. I dunno, but applaud your thought process. G/L
www.179swampthing.org
pic: A proposed drive train idea. Elgin Clock Extra Discussion 10 16-01-2005 23:29
BEST FUNDRAISING IDEA Macdaddy549 Fundraising 6 12-11-2004 15:11
Do u thinks its a good idea to start 2004 anim? Salik Syed 3D Animation and Competition 22 31-03-2003 00:48
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
Just an idea... Clark Gilbert CD Forum Support 1 06-11-2001 08:30
