Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Unread 31-01-2005, 09:34
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
FRC #1675 (Ultimate Protection Squad)
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Re: pic: Omni Idea
If you can find away to not detsroy the outer ring of the wheel, you've got yourself one of the greatest (IMHO) concepts in FIRST! Perhaps you could cut a slot in the pvc, spead it around the wheel ring, then fasten the pvc back together (industrial staples, hot glue gun?). Once those are sealed again, just put some sort of grippy material on them and it could vey well work just as well as the fancier omniwheels out there.
Let us know how much play there are in the pvc pipes when they are on there. Do they slide between the spokes much? If they aren't extremely tight around the outside rim, do they "bounce" when they contact the ground?
Keep the ideas flowing!
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
pic: A proposed drive train idea. Elgin Clock Extra Discussion 10 16-01-2005 23:29
BEST FUNDRAISING IDEA Macdaddy549 Fundraising 6 12-11-2004 15:11
Do u thinks its a good idea to start 2004 anim? Salik Syed 3D Animation and Competition 22 31-03-2003 00:48
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
Just an idea... Clark Gilbert CD Forum Support 1 06-11-2001 08:30
