Go to Post All I wanted was a game hint.... :( - JohnBoucher [more]
Unread 31-01-2005, 20:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: 1382 Brazil - Gear box
Originally Posted by Rickertsen2
LIGHT!!!! ARE YOU OUT OF YOUR MIND!!! Those side plates are freaking ridiculous. There seems to be a trend of this among FIRST teams. There is honestly no reason to make side plates any thicker than about an 1/8" maybie 3/16" if they are directly supporting wheels. Check out the kit gearbox, many of the team 45 gearboxes, the andymark gearboxes etc. Last year our gearboxes were made from 3/16" plate and looking back even that was overkill.
Granted, they're not going to be light if they're 3/8" thick. But there is more to selecting a plate thickness for a gearbox than simply choosing 1/8". Material selection is the biggest factor, because the range of properties between (for example) 1/8" aluminum sheet metal and 1/8" alloy steel plate is enormous. Furthermore, what is it supporting--is it structural? If so, what about the rest of the frame? Some robots employ non-structural gearboxes, others tie them into the chassis as integral stiffening members. You can't compare these equivalently.
Incidentally, I am personally a little bit curious and concerned as to the durability of those plastic gears. Without knowing the ratios, and the shifter design (if indeed, that's what that is), I can't say for sure--but I would definitely suggest looking for metal equivalents, just in case you run into problems during testing. (Run the hell out of it!) Maybe someone could enlighten us a little bit about that?
pic: 1382 Brazil - Prototype Robot 3 tribotec_ca88 Extra Discussion 4 24-01-2005 07:02
pic: Team 1382 Brazil - Field tribotec_ca88 Extra Discussion 2 20-01-2005 14:36
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
