Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 01-02-2005, 20:20
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: gyro help
Originally Posted by nukemknight
Kevin Watson,
We used the new code, did the recomended checks at the end of the read me file. The program compiled with no errors, but when it downloaded to the RC, the program state led blinked red and the operator interface showed solid code error.
We are using the BEI gryo chip AQRS-00075-109.
No print statements are working in the user.c code.
Make sure that you're not calling printf() before initializing the serial port(s).
Edit: And just to make sure that I haven't done something knuckleheaded, I'll load up the code on my robot controller tonight and see if I can induce a red-light-of-death.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
