Re: Floats
This is definately NOT a good engineering principle. One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. What if professionals did this? What if automotive guys said that there's a problem with the brake system, but we'll take care of it when the problem shows up. What if the communications guys said that there's a problem in making phone calls when the system is under load, but we'll wait until the problem shows up during the Super Bowl to fix it?The point is that if you know that something will cause a problem in the future, design your system in such a way that you never get yourself into that situation. Quote:
Also floats take up more program space, which is definately a valueable commodity. |
Re: Floats
) along with a few interrupts firing quite often to count motor revolutions. That's interesting that that would happen - I would have thought that as long as you hit the main loop at least every 26.2 ms you would be ok. Doesn't the master processor buffer the incoming radio data? If you do in fact need to hit that more often, than I may be completely and totally off.Quote:
Of course, everything I've said goes right out the window as soon as you start using arrays and structs and such. In that case, you may be much better off using chars or bitpacking ![]() I probably don't know enough about how IFI has this all set up to be totally right, but it seems to me that replacing variables which do in fact hold floating point values with integers just because it saves you a few bytes of space is worth it. |
Re: Floats
Dave brings up good points. I didn't intend to state that I wanted to use a ridiculous number of floats in my operations, but I've found that for certain things, the precision is necessary. However, I know that a few floats won't kill the controller and make it skip packets unless you go overboard, so you don't actually have a problem (unless I'm mistaken). If I didn't have to use floats for certain operations, I wouldn't because they do add alot more strain then any programmer would like to have in a limited resource system. I guess I'm just curious where the line is drawn between being safe in your use of floats, and when you'll start to observe packet loss (which is something nobody wants). I've been coding using the fewest floats I can while still getting the precision I need in some parts (with sensor calculations specifically).
Dave, do you know any other ways to work with the decimal calculations in these sensor calculations so that you run the least risk of having problems meanwhile still keeping the accuracy neccessary? Currently, I'm just doing my best to use the least number of floats possible. Thanks! |
Re: Floats
Also, if you ever end up developing embedded software for a living, you'll find that companies generally want to put the smallest, cheapest microprocessor inside something that they can get away with. If your company is going to ship 5 million of the newest, hottest gizmo to all the teenagers in the country, and you tell them that you need to spend an extra $1 or $2 on a faster processor, then that's $5 million extra cost to produce the product that the company will either need to pass on to the customer (and hope the competition doesn't do it for less) or subtract from the profits. In that case, writing efficient code will be seen as very important. Quote:
One trick that we use frequently is to take a 16-bit number and treat the lower 8 bits as a fractional portion. That way you can stick with simple integer math operations but still obtain higher accuracy. We've done this with all of our distance calculations from wheel encoders, angle calculations from the gyro, PID controls, etc. There are always tradeoffs where using floats is justified and a decent idea. I think Dave was trying to make the point that (like any compromise) you just need to be smart about it and not make the decision without taking some time to consider the consequences. |
Re: Floats
I agree with you about the tradeoffs certainly, that's why I was posting this thread before I got too deep to see if there were any alternatives and where I'll start hitting problems at if I don't. Thanks! |
Re: Floats
Here's how it works: Take a number, say the sine of 75° (or any arbitrary number), and express it as a 64-bit real (which is a float on this platform, if I'm not mistaken). You're using 64 bits to store a lot of different things--the numerical part, the sign (i.e. + or -) and the exponent (i.e. 10n). As it happens, the value sin 75° = 9.65925826289068E-0001 is stored as 965925826289068, with an exponent of 10-1 and a sign of +. We've got about 15 significant digits here (965925826289068 fits in the 52 bits reserved for it); the question is, do we want or even need 15 significant digits? Probably not. So let's toss some. (This is what he meant.) We can take the most significant few, say 9659, which stores neatly in 15 bits (with lots left over, actually). While we're at it, we have that exponent block of 11 bits; it's no use to us, so long as we can say for sure that all of our values are going to land within a certain range. For sine, it's between -1 and 1--which is to say, in the neighbourhood of 100. So we don't need 11 bits to represent that either. We instead assume that our data is going to be in that range, and don't even store the exponent. (This of course means that we can't use this as easily as a float, because the order of magnitude isn't stored in the variable itself--it's in our heads!) The sign bit stays, because we have both positive and negative numbers. What we're left with is 15 + 1 = 16 bits, which happens to be equivalent to an integer type that is directly supported on the PIC (16-bit signed int). So instead of working with the number 9.65925826289068E-0001 (a float), we use the number 9659 to represent the same thing (knowing that we really mean 0.9659). All of our routines, custom-written, of course, make that same assumption, but can therefore store in 16 bits what would have taken 64, sacrificing useless precision and gaining the marked advantage of using the built-in integer operations. But wait--you can do better. We've naïvely assumed that we need to use the 15 bits to store a number up to 10000 (representing 1.0000). Actually, 215 is 32768. So, if we want, we can scale everything by this proportion (3.2768) and end up with a little free precision. Once again, our functions have to know that when we input 32767*, we really mean 1.0000. Similarly, sin 75° would be handled internally as 31650. Is this representation easy to read? No. Is it easy to code? Not trivial, but not hard either. Certainly not beyond what's expected of a student in any reputable senior high school programming course. Basically, if the mere humans can get their heads around it, they can write a function to printf whatever they please, while letting the PIC do its thing with integers (which it likes). *Don't do 32768--that's actually an overflow, because we need to account for 0 in the integer number line on the interval [-32768, 32767]; it is intentionally asymmetrical. Last edited by Tristan Lall : 02-02-2005 at 02:51. |
Re: Floats
That kind of deflates my entire argument. Never mind... ![]() |
Re: Floats
Steven,
To expand for the benefit of other interested viewers, I thought I'd chime in... I am entirely in agreement with Dave, Dave and Tristan on this issue. Never use floating point... Let’s look at a sin function. According to Microchip application note AN660, the math library “sin” function has a performance of 4030 (minimum) to 6121 (maximum) machine cycles. Note: This data is for the PIC16 family. I could not find PIC18 data but I expect it is similar. As my fixed point integer representation, I choose 0x0400 = 360 degrees for my integer variable “theta”. This is a granularity of about 1/3 of a degree (I dare you to argue that you need more. A table of integers (0x4000 = 1.000) is generated in Excel for the 1024 data points required and included into the code as a rom const int array named sine_table (2K of program memory used). The statement sine = sine_table [theta]; executes in 15 machine cycles. Note that you get cos just as easy from the same array: cosine = sine_table [(theta + 0x0100) % 0x0400]; If using 2K of program space bothers you, you can use various math techniques such as a Taylor series expansion (see this thread for a discussion). Regards, Mike Post Script: I never saw Seth's last question in the above link until just now... Code:
// sine_table is an array of 1024 2FX14 integers where 0x4000 = 1.0 and 0xC000 = -1.0
// sine.csv is a slightly modified "comma separated variable" file created by Excel.
// The declaration "rom const" causes this array to exist in the PIC program space.
rom const int sine_table[DEG_360] =
#include "sine.csv"
Sorry for not responding sooner Seth... - Mike |
| Favorite Monty Python Sketch/Movie | Joe Matt | Chit-Chat | 47 | 30-03-2004 21:45 |
| EduCAD and Arrays!!!!! | Sachiel7 | Programming | 14 | 03-11-2003 03:21 |
| Exponenets and floats | Jonbca | Programming | 4 | 31-01-2003 08:28 |
