Go to Post Own your words. - Joe Johnson [more]
Unread 03-02-2005, 12:49
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Re: pic: The Robonaut's Robot
Originally Posted by Ogre
Very nice job 118. Can you explain how the arm in the middle works? Can it cap?
The whole upper body is mounted on a turret powered by a chip motor. On top of the turret is a telescoping lift system that goes up and down. The Arms coming off the lift go up to about a 45 degree angle and back down to horizontal. Out of the tips of the arm, are pnumetically powered spears that we will use to catch the tetras, off the ground and off the loading stations. We will use the lift to get higher, and then raise the arms, and while hovering the tetras over the goals we will retract the spears(they are shown retracted in the picture) and the tetra will fall on the goal.
so in short, yes we can cap.
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
