Re: pic: The Robonaut's Robot
Originally Posted by MasonMM
The whole upper body is mounted on a turret powered by a chip motor. On top of the turret is a telescoping lift system that goes up and down. The Arms coming off the lift go up to about a 45 degree angle and back down to horizontal. Out of the tips of the arm, are pnumetically powered spears that we will use to catch the tetras, off the ground and off the loading stations. We will use the lift to get higher, and then raise the arms, and while hovering the tetras over the goals we will retract the spears(they are shown retracted in the picture) and the tetra will fall on the goal.
So, you can cap 2 goals at once? Amazing!!
Could this be the robot I dreamed about?
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
