Go to Post I have no defined complaints, and I have no solution. I simply have mixed feelings. - Andrew Blair [more]
Unread 04-02-2005, 23:24
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
pic: GearBox (865)
Unread 04-02-2005, 23:25
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Re: pic: GearBox (865)
wow, that looks pretty good. It seems that it might be too heavy though, are you planning on shedding any weight from it?
http://www.wcsrobotics.com
team 663
team 1493
Unread 04-02-2005, 23:28
AKA: fffff
#0123 (fff)
well, we were thinking about drilling speed holes
Unread 04-02-2005, 23:38
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Looks good, did someone on your team do the wielding or was it sent to a shop to get done?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 04-02-2005, 23:42
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Looks really nice. I'm wondering about your weight though, the extruded aluminum is goin to get heavy, if you had gotten your gearbox welded, you should've gotten your chasis welded too or maybe used the kit chasis, was a lot lighter than our last year's robot chasis from extruded aluminum. But overall good job on your gearbox.
Unread 05-02-2005, 00:57
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Welding looks good, looks solid.
Elknise
Issaquah Robotics
Unread 05-02-2005, 01:07
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Extruded aluminum is actually relatively light. The stuff we are using is 5oz per foot for the 20x20mm and the 30x30 is 10oz per foot. So for our whole chassis that is around (This is just an estimate, I didnt actually do the math) ten pounds.
Anyway nice gearboxes. What reduction do they give you?
Unread 05-02-2005, 01:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The material itself is light. All the connectors and bolts and T-nuts are not.
2001-2004: Team 100
2006-Present: Team 254
Unread 05-02-2005, 01:14
russell's Avatar
#1430 (WRONG)
Good point. I will have to think about that for our arm design which currently calls for quite a few bits of various types of hardware.
Unread 05-02-2005, 01:16
Jeff K.'s Avatar
Hmm..now what?
Ya, that must've been why it was heavy. I didn't work on it much but I do remember that it was heavy. Must've been that, but is it actually possible to weld extruded aluminum to lighten it then if you actually plan on using it?
Unread 05-02-2005, 11:26
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
we found our extruded was coated with sumthing so if we ever wanted to weld we'd have to grind that stuff off. i think our teacher said it seemed like zinc coated. but we didnt weld anything and of course ended overweight
and that looks beefy.
Unread 05-02-2005, 13:19
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Our teacher welded the gearbox in our school (we are a technical school). We reduced the weight of this gearbox by shrinking down gears' hub and of course "speed holes".
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 05-02-2005, 14:55
Cory's Avatar
AKA: Cory McBride
Yes, you can weld it. We had it welded last year. You have to grind off the coating first.
2001-2004: Team 100
pic: Team 716 Gearbox Andy Brockway Extra Discussion 12 01-02-2005 09:18
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
