Go to Post ...our football team was a state champion, but i don't see -them- going to atlanta and winning there! :D - Sam Lipscomb [more]
Unread 05-02-2005, 03:23
roboguy #1 roboguy #1 is offline
Unlicensed "Can Do It All"!!!
AKA: David
#1047
roboguy #1 is infamous around these partsroboguy #1 is infamous around these partsroboguy #1 is infamous around these parts
Send a message via AIM to roboguy #1
Re: pic: 1351 camera mount
The one problem that might get you mad down the road so I will save you the trip. The standard cable for the camera mount which is standard serial port is heavy and doesn't like to move around alot but if you got a handy person on your team have them make their own version of the same cable using the plug put cut the cord and instal more versital setup so the lil weakling servos they give us can move. Check the torque and I believe for Hitec servos like taht it should be around 85Oz/in. not much torque so whatch out.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
Camera Mount? AnkurG Electrical 3 14-01-2005 09:26
pic: 870 Motor Mount CD47-Bot Robot Showcase 9 27-04-2004 11:55
