Go to Post While youth is wasted on the young, in FRC knowledge can be wasted on those a bit older. - IKE [more]
Unread 08-02-2005, 15:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: 195 Chassis
I don't know about birch, specifically, but good woods are generally stiffer and stronger per weight than aluminum. The problem is that its hard to get efficient shapes out of wood, so it loses its strength advantage. If it was possible to make thin wall tubing out of wood, there would be a whole lot more high performance stuff made out of it.
Team 1257
pic: 2005 226 Chassis Render Matt Reiland Extra Discussion 12 02-02-2005 00:56
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
pic: 195 Grabbing The Center 2x CD47-Bot Extra Discussion 1 21-03-2004 21:15
pic: Team 195 hanging CD47-Bot Robot Showcase 12 02-03-2004 22:39
pic: Team 190 Chassis and Driveline CD47-Bot Robot Showcase 1 01-02-2004 01:57
