Go to Post And I have to say, those days where you are just beating yourself, and smacking your head against the wall, and you just wish the robot would catch fire so you could go home, make the top of the mountain that much sweeter. - Gboehm [more]
Unread 08-02-2005, 23:46
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Re: pic: 195 Chassis
Originally Posted by Tom Bottiglieri
We have been using this tank tread/wood chassis for a few years now, and it has never let us down. We opt to keep it for a few reasons.
1) Plywood is much cheaper and easier to work with than aluminum. We can assemble the entire chassis in one day on readily available machines. We also like the plywood because we have tested it to be not only lighter, but stronger than its aluminum counter part.
2) Why reinvent the wheel? This design is proven, and we know we can depend on it to work again. Plus, every year we can tweak the design to bring it closer to perfection.
3) By knowing a general chassis and drive wheel design from the start, we have more time to focus on whatever armeture we want to put on.
LONG LIVE THE PLYWOOD BOTS. RAGE also has been using plywood for about the past 7 or so years. We also use Baltic birch, and we have only ever had it break once, in 2003, but luckily a little wood glue fixes that, instead of tearing apart the whole bot.
This is basically our philosophy as well, we usually keep the same red plywood base design from year to year, allowing us time to work on our arm and programming.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
pic: 2005 226 Chassis Render Matt Reiland Extra Discussion 12 02-02-2005 00:56
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
pic: 195 Grabbing The Center 2x CD47-Bot Extra Discussion 1 21-03-2004 21:15
pic: Team 195 hanging CD47-Bot Robot Showcase 12 02-03-2004 22:39
pic: Team 190 Chassis and Driveline CD47-Bot Robot Showcase 1 01-02-2004 01:57
