Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Go Back   Chief Delphi > Technical > Motors
Unread 19-01-2005, 20:37
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Re: 2005 Motor Information
Can anyone help with a question related to the "Intro to Motors" [Heinzmann & Mikus] presentation posted on the 2005 Kick Off Workshop List? Near the end they list a "simple strategy" of assuming a higher motor resistance to calculate a new power curve. They then say to "operate at half the new peak power". I'm wondering if it was supposed to say "... half the new peak torque". Half of the already greatly reduced power seems REALLY low.
Thanks!
Jeff Austin
Team 372
Mukilteo, WA
Unread 21-01-2005, 12:32
ErinColleen ErinColleen is offline
ErinColleen is an unknown quantity at this point
So are we in agreement then with the specs that were in the excel sheet?
~Erin
Unread 21-01-2005, 12:58
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
~Erin
I updated the spreadsheet, with a few corrections and new data - attached here. I haven't heard from Brandon if I can update the link in my post earlier in this thread.
Pete Kieselbach
Unread 21-01-2005, 14:26
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I would use THIS SPEC for the Taigene motor.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Team #88, TJ2
Unread 27-01-2005, 17:04
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Hold on a sec...
I think the oz-in numbers are wrong on the van door, jideco and denso. They're WAY too low. lb-ft numbers look right though.
ok...maybe I should investigate before I speak... When the numbers were converted from Nm to oz-in, they used mNm to oz-in conversion. I've fixed them, assuming that the spec actually is Nm and not mNm.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 27-01-2005, 22:22
petek's Avatar
What would Dave do?
Originally Posted by sciguy125
Hold on a sec...
Good catch! Funny how simple conversions can get screwed up at 10 at night... I hadn't paid too much attention to the oz-in numbers (obviously).
Pete Kieselbach
Unread 05-02-2005, 12:06
Tom McCurdy's Avatar
Tom McCurdy Tom McCurdy is offline
Physics-Electronics
#1677 (QuantumNinja)
Team Role: Webmaster
Tom McCurdy will become famous soon enough
Send a message via AIM to Tom McCurdy
I have had members of our team who are saying the gear ratio is wrong still instead of 1:124 for fisher price is 1:12.4 would this make any difference.... basically right now we are looking for the torque on the fischer price motors
Unread 05-02-2005, 13:54
petek's Avatar
What would Dave do?
It would appear there are a couple of other errors in the data:
- According to other threads, this year's Van Door motor apparently has a no-load speed of about 50 rpm;
- The Globe gearmotor stall torque is way off - it is lower than the window motors', but I don't know what is the real value.
If and when I get "real" data, I'll update the spreadsheet. Sorry for posting bogus data.
Pete Kieselbach
Unread 08-02-2005, 17:18
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
I don't understand this data.
I find it impossible to believe that the torque from the FPs is less than one Nm. Can someone explain what "stall torque" is? And then, what is the motor's "normal" torque?
Unread 08-02-2005, 19:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
The torque from the FP without the gearbox is less than 1Nm. With the gearbox, it's a whole lot more. The data for the FP with gearbox is wrong on that sheet, as pointed out by Dr. Joe earlier. Stall torque is the amount of torque provided when you are at 0 RPM. When you are at maximum RPM, you have 0 Nm of torque. There really is no "normal" torque... it depends on what speed the motor is going. I think there are power curves for the motors around here somewhere, which will tell you how much torque you get for a certain speed. If not, you can probably construct one yourself.
2007 Pittsburgh Website Award
Team 1388 - Eagle Robotics
_
Unread 09-02-2005, 00:38
Electrical Engineer
AKA: Phil Baltar
FRC #1351
As far as I know, brushed motors are linear. Plot torque vs speed. 0 speed, stall torque is your first point. Full speed, 0 torque is your other point. Draw a straight line and you have your "curve."
Version: 3.12
Unread 09-02-2005, 00:57
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I dont think thats right. Dont know why, but something seems funny about it. For I think because you are plotting the speed at stall at the beginning then the rest of the time you plot the free speed. Something like that.
Unread 09-02-2005, 01:27
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
In fact, sciguy125 is mostly right, except that usually, you plot speed vs. torque with stall torque (the max.) at the extreme right of the x-axis, and the torque corresponding to free speed (i.e. 0 torque) at the origin.
Maybe you were thinking of current?
Name:	speed-torque and current-torque.png
Unread 09-02-2005, 03:55
#833 Team Captain
AKA: Ben Honey
So, then what is the stall torque on the Fisher-Price motors (with gearbox)?
Unread 09-02-2005, 10:19
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
We don't have any official numbers, but Paul Copioli figured the gearbox reduction to be about 180:1. Take the torque listed on the data sheet for the motor alone, multiply it by 180, and subtract a bit for energy losses. That will give you a ballpark figure.
_
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
