Go to Post My puppy certainly thanks the many teams that handed out frisbees this year. - VexisDarksteele [more]
Unread 02-09-2005, 08:14 PM
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #5010 (Tiger Dynasty)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
pic: (447) Innovation Break
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 02-09-2005, 08:21 PM
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: pic: (447) Innovation Break
Yes, our breaker panel bottom is falling off too. It's annoying for sure...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 02-09-2005, 08:24 PM
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
While i have heard of some of the spikes casings coming loose this year i have yet to hear about the breaker panels opening up. Since you seem to have both of these issues present it leads me to believe this may have occurred due to your use. Have you been testing these pieces of equipment under heavy loads. I mean have you had these units on a test bed robot where it was being tested and maybe hit by another robot or was ramming an object. If you haven't I'm wondering if the box they were delivered in from your kit pick up location was ever dropped or the individual components dropped. Since all IFI equipment was delivered in an electronics box together, check your other Spikes, Victors and OI & RC to see if those casings may be loose or separated also. Just watch out what you may use to reconnect the cases together as they are made from a molded thermoplastic and some glues and adhesives (like loctite for example) will eat the plastic and damage the products beyond repair.
-Michael Dessingue
Unread 02-09-2005, 08:57 PM
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
ya ours started to come off. but i hink the 4 plastic washers that come with the panel are supposed to keep it together
Unread 02-09-2005, 09:09 PM
Nope, ours has been in storage up until recently - we haven't even dropped it yet!
Unread 02-09-2005, 10:00 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Thers the key. They stay together fine if you mount them how they are supposed to be mounted. I just think its a bit ridiculous that they have to be mounted to something to not fall apart.
1139 Alumni
Unread 02-09-2005, 10:49 PM
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
ya, ours is comming off.
Unread 02-09-2005, 10:50 PM
Next question - if anyone has had the back come completely off, is there anything important on the back? Should we worry?
Unread 02-10-2005, 09:14 AM
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
We mounted ours very early so we did not encounter that problem, however we did have one speed controller die, that was annoying!
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 02-10-2005, 11:46 AM
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
For the breaker panel - There are two pieces of metal that have a hexagon cut out of them that fit into the plastic base and hold the bolt for the 6 ga. ring terminals. Other than that its just the plastic bottom piece and the one screw that holds it on. I havent taken off te upper plastic piece yet.
Don't know about the new spike casings, havent taken one of those apart yet.
Unread 02-10-2005, 12:54 PM
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
We've had no problems with ours. Like Rickertsen2 implied earlier, it's most likely student/mentor error that caused your problem, not an IFI defect.
Unread 02-10-2005, 01:58 PM
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
He did mention an IFI defect...
I think IFI provides us with a great set of tools to quickly and easily develop a very powerful robotics control system. The RC, OI, Victor, Radio Modems and Spike are great components. Sure, they are expensive.
We can only speculate why parts from IFI are so expensive. Whether it be limited production quantities, big discounts to FIRST, labor costs or a mix of a number of reasons. These components are pricey but most seem like it's money well spent for quality components.
Frankly, I'm not as satisfied with the Breaker Panel as the other components. We ordered an extra Breaker Panel and we see the same problem with both. Unless they are securely mounted the cover wants to come off. Who knows why that is- it might be that FIRST asked for these to be developed in December. You just don't know. I just hope that next year they implement a better system to protect the PCB and electronics on the Breaker Panel.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 02-10-2005, 02:15 PM
Retired -- 2006
Maybe I misinterpreted his words, but I stand by my original statement. We've ordered an extra, as well, and have had absolutely no problem with either, or any other IFI component.
Unread 02-10-2005, 05:24 PM
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Team 121 has managed to break or destroy multiple kit components this year, but everything provided by IFI has been great. It is possible that some components may have been damaged in shipping or by rough handling. If you are careful with the components and mount them properly then you shouldn't have any problems. If a component arrived broken then it was probably damaged in shipping.
I think that IFI has done a great job creating components to better suit the needs of FIRST teams. You should see some of the electrical shennanigans that took place before IFI started providing components! We should really be greatful about what we are given in the kit. The quality and easy implementation allows more energy to be focused on creating a competitive machine, not just getting one running.
Rob
Unread 02-10-2005, 09:27 PM
rufu5's Avatar
20something
Don't get me wrong, I'm not saying I'm not grateful of what IFI gives us. I just remember the glory days of the old screwed together spikes that never, never came apart and rarely ever had to be replaced.
These parts have been through two boards and regular robot use that can be expected during competition.
P/N SPIKE-RELAY-H $34.95
P/N: BREAKER-PANEL $84.95
P/N VICTOR-884-12 $114.95
I just dint like this new design, the roundedness, all the glue, one screw on the whole breaker panel. I just want throw back spikes man
Well I am kind of biting the hand that feeds me. I love you IFI! Just trying to raise a valid criticism to better the kit for next years bunch.
-Salvador Dali
pic: (447) Chassis Weight + Appendages rufu5 Robot Showcase 6 02-09-2005 05:55 PM
pic: 447 Teaser rufu5 Extra Discussion 7 01-30-2005 09:47 AM
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 01-17-2005 07:10 PM
pic: 33 / 447 CD47-Bot Extra Discussion 1 07-11-2004 02:31 PM
pic: Sleepy 447 CD47-Bot Chit-Chat 4 05-23-2004 09:31 PM
