Go to Post The heat gun is not an arm rest. Especially when it is on. - Fuego247 [more]
Unread 11-02-2005, 18:18
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Re: pic: Close enough?
Yes, although you can't tell from the picture, the set-up is mounted to the frame.
No, we haven't had any heat problems. We've got about 20 minutes run time in various tests, including having one of the team (130 lbs.) ride on it for about 2 minutes.
The entire drive train comes in at about 55 lbs..
We tried to get clear aluminum, but it was on back order. They said it would be in by March 3, 2150
Good luck to all!
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
So close, but not close enough archiver 2001 1 23-06-2002 23:45
