Go to Post You're not crazy. Eleven is the new seven. - Michael Corsetto [more]
Unread 02-11-2005, 02:53 PM
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
pic: Close enough?
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
Unread 02-11-2005, 02:54 PM
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Re: pic: Close enough?
Wow... i thought ours were a close fit with an entire 3/4 of an inch..
Unread 02-11-2005, 03:06 PM
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Holy cow, thats mighty close. Have you experienced any problems with a setup that close?
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 02-11-2005, 03:28 PM
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Yeah but is your robot is connected?
I do not see any frame???
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 02-11-2005, 03:59 PM
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
that's a little too close I think.. Might have a problem with the motors heating up quickly. Besides that. good job.
Unread 02-11-2005, 04:07 PM
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
That's some pretty hefty plate on the sides, too... how much does that setup weigh?
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 02-11-2005, 04:27 PM
I really like this team's invisible chassis. I think I know what they are using, but I doubt that transparent aluminum is within the FIRST budget limits.
- Montgomery Scott
Unread 02-11-2005, 06:18 PM
S.Nickens's Avatar
Morpheus
#0011 (M.O.R.T.)
Yes, although you can't tell from the picture, the set-up is mounted to the frame.
No, we haven't had any heat problems. We've got about 20 minutes run time in various tests, including having one of the team (130 lbs.) ride on it for about 2 minutes.
The entire drive train comes in at about 55 lbs..
We tried to get clear aluminum, but it was on back order. They said it would be in by March 3, 2150
Good luck to all!
Unread 02-11-2005, 07:33 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Wow, nice job getting the wires out of there. Im scelptical about you getting the motors to run for 20 minutes without heat issues, but who knows. Just be careful, they heat up a lot quicker under large loads(aka a shoving match).
Unread 02-11-2005, 08:21 PM
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
We have the identical setup with the backs of the CIM's backed up into each other. So far no problems especially in 2 minutes
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 02-11-2005, 08:26 PM
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Last year we mounted our two chips pretty close, but not that close. We just had to be a little careful and get some of that really cold compressed air for in between matches. What was really aggrivating was when we had trouble with our transmissions. After a little while we realized the chips were plugged in wrong due to the fact that you couldn't follow the wires very well. So if nothing else i strongly recommend you mark your chips so you can distinguish them just in case.
Unread 02-12-2005, 12:34 AM
Brandon Holley's Avatar
We didnt run them for 20 minutes straight, he said we've ran them for a total of 20 minutes...including 130 lbs of weight on top for 2 of them........just to clear that up
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 03-23-2004 11:38 PM
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 03-04-2003 03:23 PM
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 02-25-2003 09:07 PM
So close, but not close enough archiver 2001 1 06-23-2002 11:45 PM
